Severe Oil Blow By, need help fast!
TT91
1,536
Paramus, NJ
I wrapped some paper towels around my breathers and went for a 3 mile highway cruise, under boost a few times, maybe 4-5 psi. This is what the towels look like afterwards, soaked in oil. I have a breather on each valve cover, and the PCV is plugged. I am supposed to be getting tuned in the morning and I would like to fix this for the time being. Any help???
If you have one, hold an airhold (such as when changing valve springs, holds air pressure in the combustion chamber) and see where the air is leaking to. If it's comming from the heads it is most likely a bad valve seal would be the first place I would look.
i copied this out of a thread link is at bottom don't know but hope it helps.
1) i installed a chack valve between the upper intake and the pcv so that under boost, no pressure would get past the pcv valve and into the crankcase. 2) i installed an open element breather that replaces the stock oil fill cap on my stock valve covers. i have not seen your valve covers, but i know they are not what the factory provided, so, if you choose to get an open breather, the opening in the valve cover MUST have a baffle.
THANKS FOR THE HELP yea the friggin techs at vortech sent me in the wrong direction. they had me eliminate my pcv and like you said the supercharger was boosting my crankcase forcing oil into my manifold aswell . put my pcv back in and threw there pcv bypass kit away . motor runs great no oil leak no dipstick poppin out . so my problem is solved . now i need a msd box with a revv limiter so i dont blow my motor
http://www.corral.net/forums/showthread.php?t=707745&highlight=blow+supercharger
Thanks bill, Im confident that the motor has a tight seal. I just ran a copression check on cylinders 5-8, all reveal 125 psi and holding. I need to look into a check valve breather option.
Holy **** that is bad, did you try new/different breathers? Oil drain holes in the heads clogged with something and not draining back into teh pan fast enough? IDK just saying but it does sound like you need a to re-evaluate your pcv system. Bill302, sounds like you may have hit it square on the head.
TT91 said:
They have them. Compression test is 125 across the board. Ill be making some sort of evac system tomorrow.
Hmm,then you could try putting a piece of tube under the breaters to raise them alittle.
Or you can get a breather tank,run hoses to the breather tank,and put an air/oil separator in between,with a line back to the oil pan.
Or,you could set-up a vacuum pump like we did and pick up some more power while fixing your problem.
:D
Wouldnt it have to be from something recent, i no u had put a few miles on the motor and u didnt say anything about doing it them, but last i remember u tore heads off and had to get new injectors and that u got a new hood. And didnt u get new valve covers too? or maybe that was someone else. My friends Blown Notch has a Supra pcv valve in place of his or something like that to prevent the blowby while under boost like someone else said, and he is running an open breather on the oil filler cap. he also has a oil seperator he got from home depot to get moisture out of air tool systems and put it in his pcv line and it helped alot.
Thanks Rick. I'll let him know. I think it will take something like that to make it right.
He put on a Steeda seperator and it was full after 2 pulls on the dyno. :bang:
He was so mad he took it off and threw it into the garbage.
He just has the PCV blocked off right now and a breather on the driver side VC.
