  • SN95 4.6L Mustang Tech
shifter
  • Thread starter Thread starter cronin49
  • Start date Start date Dec 19, 2004
C
cronin49
Banned
Aug 12, 2003
432
SC
Dec 19, 2004
  • Dec 19, 2004
I am looking at the UPR Adjustable Shifter Handle. I know all about the after market shifters available, Steeda, MGR, Pro, etc. and do not wish to purchase one of those at this time. UPR says their unit will shorten the shifts, and that is all I'm looking for. In my opinion, all the other shifters I mentioned do the same thing, shorten shifts, but at a cost of $175 versus $30 for the UPR. The primary difference between the stock shifter and all the after market shifters is that the after market shifters shorten shifts by simply shortening the length of the shaft. I proved this to myself by taking the knob off my stock shifter and holding the shaft about halfway down, I went for a ride and shifted in this manner. the shifts were much shorter, due simply to the different geometry. Anyway, I am going to give the UPR unit a shot, what the hell, $30 bucks is chump change, so I have nothing to lose. Any opinions? Does anybody have this unit? Thanks.
BadMoFo
I will sleep with a Mod for a CT
2,911
New Bern NC
Dec 19, 2004
  • Dec 19, 2004
there is a huge diffence in getting an aftermarket shifter and just getting a new handle. trust me. I could beleive the difference in shifting when I got a new shifter on my cobra. just getting a handle wont be the same, sure it will be a little different but go ahead and buy the whole shifter, and I bought the upr shifter for mine, identical to the steeda triax but cost less.
C
codyGT
365
Nebraska
Dec 19, 2004
  • Dec 19, 2004
Actually the shift handle length has almost nothing to do with a short throw.
A complete shifter uses a completly different piviot point to achive a short throw.
There is a big difference between a shifter handle and a complete shifter. Using a shorter stick has no effect on the movement of the shifter it takes the same distance to engage gears.
C
cronin49
Banned
Aug 12, 2003
432
SC
Dec 19, 2004
  • Dec 19, 2004
I don't agree with you. When I did my experiment, my hand moved about 6 inches between 1st and 2nd with the shifter ball on. When I removed the shifter ball and gripped the shaft about half way down, my hand moved only about 3-4 inches. So if I was an idiot and cut the shaft down to half its length and screwed on a knob, the throw would be shorter. Granted, shaft length doesn't have everything to do with the throw, but it sure has something to do with it. Shaft length is ONE reason that after market shifters are shorter, but not the only reason.
C
codyGT
365
Nebraska
Dec 19, 2004
  • Dec 19, 2004
You can put a 1 inch handle on it and it doesn't matter.
Of course if you use a shorter shift handle your hand will move a shorter distance, you are moving a lever on a fixed point. The other end of the shifter is still moving just as far as before.
Take a stock shifter and a aftermarket one, remove the handle. Measure the distance the top of the shifter moves.............
Sick96Stang
621
Gilbert, Arizona
Dec 19, 2004
  • Dec 19, 2004
You might as well just go for the whole shifter the steeda is what $150? Not to mention with that shift handle you wont have the smooth 2nd to 3rd shifting you would with the Tri-Ax or some other aftermarker shifter.
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Dec 19, 2004
  • Dec 19, 2004
I like my Steeda Tri Ax!
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
P
Drivetrain 1988 T5 Grinding going into 2nd gear, '92 Camaro transmission swap or parts?
  • pindude80
  • May 7, 2024
  • 2 3
5K
Fox 5.0 Mustang Tech Jun 11, 2024
LILCBRA
C
AOD wont go into park
  • chris1993
  • Mar 4, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2024
Silverfoxx
