I have just installed the engine in my 65 289 after rebuilding it .... new pistons, cam, timing gear, lifters, valve springs, pushrods, oil pump, bearings, flywheel, clutch etc. I thought I'd done a real good job ... until it came to start up time. The car started, ran for about 30 seconds, then backfired. I shut it down then tried again ... ran for 5 secs. then backfired with flames coming out of the carb (holley 650) I had nothing to put the flames out with, so I just wacked the carb several times on the top with my Mustang wiring diagram ... this eventually put the flames out!!
Then I called a pal of mine who came round and we checked everything we could .... the timing, firing order, changed the plugs, dist.cap, spark plug leads to no avail. Then we removed all the leads one at a time from the cap and tried to start it after each time ... car still backfired every time. We have pretty well eliminated electrical problems and now seem to think the cam timing may be a tooth off. Any ideas what the fault could be before I wheel the whole thing into the ocean
When the car was running the backfire was quite regular as if it was just one cylinder .... if that means anything.
The problem was the rocker arm nuts were not going far enough on the studs (screw in) to engage the locking bit ... this was happening on several which were working loose and causing vales to not open when they should leading to backfires etc. As a quick fix I have turned the nuts over so the locking bits are at the bottom and now sit really firm. I am just ordering some longer studs ... I only wish that Comp Cams had specified longer studs with the roller tip rockers I bought, then the problem would not have occured in the first place.
