Side Exhaust
If you put that exhaust on, you should paint the car black... Oh wait, what I meant to say is don't listen to what these guys are saying about YOUR car. Do whatever you want. IMO they look fine.
xj220 said:
How would those work with subframes though? I've got a pair of TCPs and they go pretty low.
kind of a 'one or the other' situation... Running them under a sfc would leave you cringing with every sight of a driveway. Some options are notching and boxing the SFCs or running the SFC thru the floor inside the car.
I've had the question asked about 300 times so here's what I did...
The Dr Gas set-up is all mandrel bent. I would have used it but the TCP Center section was in the way. So we used in-line flowmasters and just bent the pipe out to the side. I ran it right behind the outside sfc. I'm pretty sure I can get some cal tracs under there with a little massaging!
iskwezm said:
i dont think they will work or with traction bars.I have a similiar exhaust that i put together and i cant use either
Shelby underrides were no problem. I used them with mine.
For SFC's, you have several options: the best is thru-the-floor SFC's - strongest & no clearance issues (also hardest to do). You can also run a setup like MDJay pictured, or Spintech sells both oval tubing & "clearance tubes", which are dimpled for SFC clearance.
I think my pipe comes out right at the spring mount and i've already spent too much on mandrel tubing to change it again,so i have to look again,but i REALLY need something,i'll look into that,thanks
question for mdjay: with your setup would you have clearance issues with shelby underride bars? I like the idea of running a flowmaster as they don't make a inlet/outlet same sided muffler. thanks.
They are a tad loud, but it is only a week end play car, so not bad. Those are Dynomax Race Bullets which use ceramic instead of fiberglass, and do not sound like glass packs, or pop like them. Not too loud, but I would not want them on a daily driver.
