Couldn't stand the Uncle Jessie tow truck sound the Dynomax #17676 side-exits I'd rigged up a few weeks ago were making after the initial break-in period, and I wasn't happy with the funky curved-back tailpipe look, so I re-installed my old stainless steel Dynomax tailpipes and Pypes Violator mufflers again (in the parking lot of Autozone, heh).
It's a tad quieter, but the sound is more pleasant (I never hated the Violators' sound in the least, always loved it), and with the Jeg's off-road X-pipe that actually has tranny crossmember hangers (unlike the piece-o-crap UPR X-pipe I took off), I've got perfectly stock-level ground clearance. No more scrapes and dragging. Hardest part was getting everything to line up jussssssst right and leave enough wiggle room (about 1/2" minimum clearance everywhere) so I wouldn't be fighting rattles and thunks again. So far, so good. Gotta wait until morning 'till I can see whether I've got the tailpipes even and level, though - did everything in the dark by flashlight and blind feeling around.
Anyway, to the point, a quick tip to anyone purchasing a set of Pypes Violator mufflers and installing them on any other brand of cat-back (aside from Pypes' own cat-back, which is probably designed to fit betteR). YOU WILL need to chop about 1" off the end of your flow tubes (pipes between your X- or H-pipe and the mufflers) to avoid rubbing your tailpipes on the rear axle housing. The Violators are 2" longer than the OEM-fit and cat-back Dynomax Super Turbos, so the extra length pushes things back a tad too far for comfort - chopping 2" off your flow tubes is too much, though, as you'll wind up running into the minor bends of those pipes with your slip-in fitting of the mufflers.
I'd go through the hassle of posting video/audio clips again, but since its the same cat-back I had on before, the only difference between before and after is that it's exactly the same sound as it was with the UPR X-pipe, just louder (due to the lack of cats on my Jeg's X) and a tad more raspy. You definitely notice the hollow-can sound right away versus the dead-flat poppy-pop tone of the Super Turbos ... probably next to nothing for sound insulation material inside the Violators (just a straight-through tube with louvers notched into it) ... but there's still no drone, so I'm a happy camper.
