Side Scoop installation
  • Thread starter Thread starter mtymo_
  • Start date Start date Feb 23, 2007
M
mtymo_
  • Feb 23, 2007
I'm doing the final body prep on my 66 and have a set of side scoops to intall. I've seen alot of artical saying they were installed but never how they did it. I just assume they are bonded on. A few tips from those that have done it would be a help. Thanks............mm
T
tillerman85
39
  • Feb 24, 2007
Mine are riveted on. One way is to tape them where you want them and then drill from the interior of the car through the body into the scoop. Don't move the scoop between drilling holes. I think mine are held on with 9ish rivets, 3 top, side and bottom. I got a long enough rivet so I could use a washer on the inside of the scoop to back up the rivet so it doesn't pull through the fiberglass. if you do this route don't drill your holes to close to where the mounting flange on the scoop makes it's bend, or you won't be able to get the rivet in. I can try to get a pic tomorrow.
R
Ronstang
1,294
Houston Texas
Feb 24, 2007
  • Feb 24, 2007
The originals were riveted on.
M
mtymo_
  • Feb 27, 2007
Thanks
Thanks for the tips........mm
M
mtymo_
  • Mar 10, 2007
Done
I just put them on. I talked to a few others and the paint store. I decided to use a commercial panel glue, Lord Fusion. It had a 90 second set up time. I did it under the recomended temp giving me more working time. The good and bad, it will never come off now.........mm
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
