Simple brake line route question
  • Thread starter Thread starter sparx
  • Start date Start date Dec 16, 2009
sparx
369
  • Dec 16, 2009
I cannot recall thru which hole (near the wheel) my passenger (front) brake line should run.
I have two identical holes, one low as on the driver's side, and one that is high through the shock tower.
My car is a 66 coupe, if you can let me know which one is correct I would appreciate it.
I think it should be the lower hole.
Sparx
tx65coupe
Dec 16, 2009
  • Dec 16, 2009
My 65 only has one hole that I saw. It is in the same place as the driver side on the lower shock tower. The brake lines run to the same place on both sides. I would say your 66 is the same. Make sure you put new grommets.
sparx
369
  • Dec 17, 2009
thanks man
Yep got new grommets.
sparx
tx65coupe
Dec 18, 2009
  • Dec 18, 2009
Your welcome. I hope it goes together smoothly.
sparx
369
  • Dec 18, 2009
Yes I got it done, made a couple of errors bending all the lines (trashed a couple of pieces), but I did it myself and it turned out nice.
sparx
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
A
SN95 Hydroboost in a Fox | Brake lines
  • arc_jpiv
  • Sep 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 14, 2026
2000xp8
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Fuel 87 5.0 Fuel rail lines
  • Mcmahst
  • Jan 21, 2025
Fox 5.0 Mustang Tech Feb 11, 2025
Mcmahst
