provide at least one pic and SOME sort of description of what she's like...lamrith said:Depends on the package you are buying...
Make sure to take an extended test drive to make sure there is no bent framework or poorly working items hidden under a nice paintjob. Nothing worse than getting it home to find out the ECU is flacky and the damn thing just does not run right, or there is a bad interior squeek that you cannot fix. Tends to make things less enjoyable and you miserable.
Passes the test drive, sign away and relax knowing you got a good one, everything else will work out.
WaterPog said:BTW, what ever happened to the "Stang Raper"?
you have to move to nevada for that95BLKGT5.0 said:Just rent the bitch when you need her.
Ha HA03yellowvenom said:consider a lease program with the option to buy![]()
i'll have to remember that one....same can be said for men too....This is true, but full service is requiredstang_lover69 said:i'll have to remember that one....same can be said for men too....
03yellowvenom said:This is true, but full service is required![]()
WaterPog said:Just remember that there is no such thing as a SANE woman and you'll be fine.
