5spd GT said:They sell thermactor plugs which "plug" up the hole where the smog equipment goes (the same thing works for the front of you heads...you can get them at a Ford Dealership - part # F4ZZ-6E086-A or you can buy some from Summitracing - part # TFS-51400265...they work in the front of your heads and back of your heads and are meant for blocking the smog pump holes and letting your alternator and powersteering (on front of motor) bolts turn into your heads...
They are cheap and run anywhere from $2-8 bucks a piece...depending on where you get them...
It also provides for a much cleaner installation...
Speed_Demon1965 said:I have seen those. But they look like it takes a screw driver to screw them in. How difficult is it to get a short screw driver to install them when the engine in the car?
88SC_GT said:well if you read my posts, i said i couldnt find anything to work. i can plug it with bolts i dont have can i?![]()
it was either halfass it with plugs or leave them open. which would you choose?
