Progress Thread Slow Boat To China
Let me know if you have any issues with that brake kit. I know I did at first. And it looks like you cut the steering shaft already but I know I had to cut as absolutely close to the rag joint as possible and it still barely reached. I'd pull the shaft and put it on out of the car. Its a real bitch to line it up on a collapsible shaft.
Glad you're gettin somewhere mang
Good deal. You've got too many pages to find your specs (I didn't try very hard) but I remembered the BTR cam and truck manifold.
Have you got the front drives yet?
Trying to play match maker with the truck/car parts was a PITA. Definitely spent a couple hundred more than needed.
Need an alternator. Going to make a bracket that I saw another guy make, looks like it took him an hour to make and install it.
I accidentally bought an alternator today for $64 from the used auto parts place in town. It's a 105 amp, should be good enough, huh?
Also paid $21 for the water pump gaskets. They're 2 identical gaskets that together couldn't cover a dollar bill completely. Wtf!
So with my parts, I went home and stuck the pump on and began designing the alternator mount like I always do things; no planning, seat of the pants style. I think I'm on to something fantastic that will utilize the stock tensioner instead of doing it old school by using and adjustable bolt. Ill wait to show pics until I settle on a final design.
Should get some boxes from the brown truck tomorrow as well. Seem to have some momentum going again, let's see how long I can keep it going!
105 is the stock size anyways.
Depending how you end up with your accessories I highly highly recommend a katech/compcam tensioner. Stock LS ones are notorious for flying off at any decent rpm.
Be interested to see what you've come up with, I know a few guys who were unsuccessful keeping a belt on a turnbuckle type setup
Here's something close to what I came up with. I messed with the tensioner orientation a little more after I took this pic to get the best rotation/tension. Going to finish welding everything up tonight and paint it. Also going to cut off all the extra steel under the tensioner. I originally planned on having closer to the balancer, but it migrated north.
As far as alignment goes, it was a tedious process. The alt and tensioner are within a 1/16" of the balancer, so I called it good enough.
Brown truck came yesterday, but only had my steering shaft piece from Speedway. Maybe UPR will show up today.
I'll put these up as a motivator for myself. Stock hood won't work without the help of a sawzall. Turbo flange needs to be cut down 1.5" and forward 3/4". Mocked up manual brake MC to run lines, but didn't have the right fittings. Got the steering shaft hooked up and cleaned the garage.
