I actually did all of the work myself. The only thing I didnt do is bore and assemble the short block.
Sorry my mods are:
-Eagle 347 kit w/ speed pro hypers 10.5:1
-No name aluminum heads, 190cc int. ports, 2.02int, 1.60exh. valves
-Comp cam 544lift, i dont have the part # on me
-Typhoon intake mani and 70mm tb
-bbk longtubes, off road x, flowmaster cat-back
-tremec t-5, 3.73s, stock diff. w/ lucas diff. fluid
-ac and smog pump delete, bbk pullys, electric fan
-stock distributer, msd cap and rotor, blaster coil, fms 9mm wires, autolite ar135 spark plugs gapped at 45
-steeda lowering springs, kyb gr-2 shocks/struts, caster camber plates, full length subframe connectors, solid tranny mount, prothane motor mounts
I dont have my time slip on me. Ill post it when i get home. I know my best 60' was a 1.9, but i usually get 2.0-2.1 and my 1/8 was a 8.5
Hope that helps. Do you guys think that it would be faster if i broke the engine in more. It does have hypers and i only have 3500 miles on it.
Thanks.
