Use a period once in a while, seriously.
If you are referring to the long metal air injection tube that runs from the air diverter valve (the plastic valve that has three hose connections to it, by the passenger side cylinder head) to the cats, and provides fresh air to the cats, than your rant about not being able to afford anything doesn't matter all that much.
If that is the "smog pipe" you are reffering to, than taking care of your problem is as simple as removing your Thermactor air injection system from your catalytic converter-less car. Remove the pipe from the valve to where the cats used to be, remove the air diverter valves (two of them) between the smog pump and the air injection tubes, remove the air injection tube at the rear of the cylinder heads and plug the holes with pipe plugs or something similar, and remove the smog pump. Or, you could leave the smog pump mounted if you are lazy and just bypass it, as has already been mentioned.
Either way, your grand whopping total will just be the pipe plugs and a new serpentine belt. If you're on a budget, Goodyear and similar brands make serpentine belts under "Milage Maker" and other similar economy names for about $20 at most chain parts stores.
