Smog Pipe or Pump
gtmustang199508
I removed the cats on my exhausts system and the smog pipe is not in my new exhausts. I didn't want to remove it at the moment but i wanted the noise that it makes when i rev it up to go away. Should I cap the hole? Or should I leave it open? Is this bad for my car to leave it open or to close it?
Thanks,
Mike
Its not that I dont want its just I cant afford bcz Im 17 years old and have to pay insurance and gas and a 5.0l is alot of gas and car insurance is 270 dollars and my job pays me 8.00 an hour which i have no extra money and Im looking for the easiest way to get buy with making it not sound like **** and not spending all my money
Use a period once in a while, seriously.
If you are referring to the long metal air injection tube that runs from the air diverter valve (the plastic valve that has three hose connections to it, by the passenger side cylinder head) to the cats, and provides fresh air to the cats, than your rant about not being able to afford anything doesn't matter all that much.
If that is the "smog pipe" you are reffering to, than taking care of your problem is as simple as removing your Thermactor air injection system from your catalytic converter-less car. Remove the pipe from the valve to where the cats used to be, remove the air diverter valves (two of them) between the smog pump and the air injection tubes, remove the air injection tube at the rear of the cylinder heads and plug the holes with pipe plugs or something similar, and remove the smog pump. Or, you could leave the smog pump mounted if you are lazy and just bypass it, as has already been mentioned.
Either way, your grand whopping total will just be the pipe plugs and a new serpentine belt. If you're on a budget, Goodyear and similar brands make serpentine belts under "Milage Maker" and other similar economy names for about $20 at most chain parts stores.
