I just had this problem today to. Hoses were going to crap. Also, whatever that hose is that you have in a pic, try pluggin that and seeing if it works. Where was it going to?
I did plug the black hose back into the metal pipe that runs back to the heads. Then I REconnected the little wire that plugs into the top of the evap cannister and nothing changes. I'm wondering if I knocked something loose when the smog pump initially came out. It kind of fell and pulled the hoses it was connected to.
Anyway, the more and more I read I'm beginning to think it's a vacuum problem for sure. Like I keep saying (over and over again unfortunately
) my car ALREADY had a problem of stalling when I hit the brakes. BUT.....before I did the smog pump today I was able to slowly come to a stop and push the clutch in at low rpms to avoid stalling COMPLETELY. That in itself is a sign of a vacuum leak.
Now I can't even keep the car idling. As soon as I start it, it revs up and then dies instantly. HOWEVER, if I start it and then give it a little gas for a minute I can get it to idle temporarily. Once I start driving it's a different story. As soon as that clutch goes in the rpms PLUMMET. ALL THE WAY down.
