SMOKED A 5.0 NOW IM SMOKING MASELF
HI I AM A CURRENT OWNER OF A 96 GT....LASTNIGHT I GAVE IT A GOOD RUN AGINST A 94 5.0. AND DROVE FOR 20 MINUETS AFTER TO MY RESIDENCE WITH NO PROBLEM.....IT ALL STARTED THIS MORNING I DROVE ABOUT 10 MINUETS AND MY CAR STARTED SMOKIN FROM THE STOCK EXAUST LOCATED UNDERNEATH THE CENTER OF THE CAR THE SMOKE IS WHITE AND THICK.....AND IM EMBARRASED TO SAY BUT IT DOES A STUTTERING PUT PUT MOTION WHEN RUNNIN.....CAN SOMEONE HELP ME OUT ON WHAT THIS CAN BE?:shrug:
Please for the love of God turn off your caps lock.
You may have a headgasket issue (very unlikely in these cars, but sounds possible here). I'd go rent a compression tool and do a compression test in all 8 cylinders. You're looking to see that the compression values are relatively even cylinder to cylinder (10-15% variance is not a big deal).
i bet that 94 car isnt spitting white smoke out from under it, and i doubt you smoked a 94 unless your car has a ton of bolt ons and that car was bone stock, because my p/i converted 98 with gears was not much faster then a mild bolt on 5.0 car. matter a fact my 94 now with 273 with a ported intake exhaust and cai is faster
All jokes aside, mine did the exact same thing last week... I swapped out my muffler bearings and now it runs like it did when it was brand new!! Check those or maybe, just maybe you blew a basket and your leaking oil onto the exhaust. If the smoke is coming out from under your car, its the muffler bearings. If your car is on fire its an oil leak. HOPE THIS HELPS!!!!
I gotta get in on this... I don't think they understand... Uhmm.... GAHHHBLAHHGAHH... MUFFLER BEARINGS... GLLHHLG1!!! BLINKED FLUID AND NEUTRON FLUX AMBASSADOR DRIVE. whew, I passed along the info guys. Good work, they should understand now. Hopefully I helped out....... Heh..
How bout this capital **** YOU BITCH:mad:
You still don't know how to use punctuation.
To say it correctly would be
"How about this capital, **** YOU BITCH!"
See how I used a comma, and an exclamation point?
But this time you did actually use capitalization correctly, since you were yelling "**** YOU BITCH". Unlike your first post where you just used caps lock for every letter. :rolleyes:
:shrug:
I think he's just mad because my slow ass Silverado can outrun his Mustang. (If his mustang were actually running that is.)
:P
:shrug:
