- Jan 24, 2016
- 70
- 12
- 18
ok fox body fans i am stumped this is what i have 87 gt 302 i have a b cam trick flow twisted wedge heads 1:6 rockers 19 lb injectors shorty headers no emissions o2 sensor in header upper and lower explorer intake msd autolite plugs gap at 50 fuel pressure at 35 tps set at 920 65 mm throttle body timing set at 14 idel at 850 car runs shifts good but my problem is that it smokes white smoke not black it is not antifreeze the level has been the same for a month new head gaskets it is even smoke out of both tail pipes will make your eyes water did compression test all balance out at 145 plugs burning all clean light tan none are black any ideas were to look or change
