Snikt89GT
5spd GT said:You might try checking your rpm again. 3-400 rpm difference is pretty steep between an actual 70mph and 80mph.
What year tranny do you have? Correct speedo gears? You sure you have stock 3.08:1's? You don't think they could have been changed?
Speedo accurate? Tach accurate?
I'll check it again the next time I drive, i'm positive it was 2,500RPM at 80MPH though. I checked the speedo with a friend on the phone and it's accurate, don't know how to check if my tach is accurate?
The previous owner said they were the stock 3.08s and it doesn't look like they have been changed.
I have an 89 1/2 - 93 T5 tranny with 8T driven gear
....when i put it in overdrive from 4th it drops 400-500 rpms does that seem normal? cuz it seems like it should lug down alot more into 5th but it doesnt.....at 2,000rpms in 4th gear im at 43mph and when i put it in 5th at 2,000rpms im at 54mph
