Starter soleniod??
asecretfile
228
Working on a 3G alternator upgrade and once I add the 4 gauge wire from the alternator to the positive side of the starter soleniod, theres so much crap plugged in there that I cant get the new wire on and the nut fastened because all of the length of the soleniod stud is occupied. Can one of those be jumped or pigtailed or something to make room?
thanks
ok thanks that worked
also the screw broke off the old solenoid when I was loosing the nut and I bought a new one and the wiring diagram shows it wires reverse of what the old one was...whereas the positive post was on the left, new one its on the right
had to double check to make sure I didnt have it upside down and nope cause it has the mounting holes in the wiring diagram for orientation
hmm
Starter solenoid wiring
Connect the fused 4 gauge wire to the alternator and the battery side of the starter solenoid.
attachment.php
Do you have an aftermarket starter relay? The Motorcraft ones have longer threaded studs then the ones I've seen from parts stores.
If you still need to to make room on the stud for the new alternator wires, you could run one 10 ga. wire, with terminal ring, from the relay to a distribution block or insulated power stud, like this
, then hook the power window, EEC, and old alternator wires to it. Mount the distibution block or stud close to the relay, and all the wires should reach it.
Just one solution to consider.
A block like this is a nice way to do it. I would use a larger jumper cable however.
One note to TRWXXA: I'd suggest making a note about that alternator statement. Someone might not realize that you meant to do this if you have a 3G and do not have the alternator-side of those charge-wires connected. Otherwise, if those stock charge-wires are carrying any alternator load, the 10 AWG jumper wire [between the stud and solenoid] could become an issue.
We all knew what contingencies you had in mind, but it's nice to be real explicit for those who are not as familiar with the logistics.
Good point!
I assumed everyone would understand that:
A.) This is for the 3G conversion with wiring upgrade.
and
B.) They should NEVER use the factory power wires when doing the upgrade.
But I realize that if I A-S-S-U-M-E this, someone will make an A-S-S out of... THEMSELVES by not reading any of the 192,328 threads on how to do the 3G conversion.:D
