ac wot cut-off relay. It turns off the a/c when you mash the throttle so you have more power and you dont break the clutch inside the compressor.
i dont have ac so do i need to buy one for my harness lol
That thing is the vacuum pump. If you want cruise and the 5.0 had it. Switch it out. Or atleast switch the cruise cable. I think there are two nuts on the back and it pulls out. Then you unhook it. the vacuum hoses. I know the one with that fitting goes to the brake booster. I can't really tell what the other one goes to. google vacuum diagram 5.0 and you'll find a few write ups with pictures. Heres one place.
Mustang FAQ - Engine Information
i went out and looked at the donor car and i see its got lines runing into the car and something is hooked to the brake pedal the whole thing looks like a bitch to remove so could i cap off the line and not have cruse control if so would i run into problems codes etc
I don't know what your talking about. If your talking about the brake booster you can use the 4 cylinder's. The cruise cable is not a vacuum line so you don't need to cap anything.
I would seriously run away from this ,and buy a Complete running 5.0 car dave181760.
You would be thankful in the long run.
But..on that note..good luck .![]()
I wasn't bashing him.I went through this a while ago,in the end it wasn't worth the headaches I went through at the time.Just because you didn't have the ability to complete the swap doesn't mean nobody else can.![]()
Im not bashing but i am subscribing because im gonna wanna see how this works out for the little ankle biter
