dennis112
Jimmys66 said:Dennis am I reading this right? You got a stealth intake on a stroked 351 to fit under a 65-65 hood?
If you did, you just screwed up my plans for a 347.![]()
Well, I used to have a Stealth. NOW I have a Vic Jr. instead and it too fits under the 65' hood (nothing located in the Shelby hood scoop either.)
For the Stealth I used strengthened 65' type motor mounts, the air cleaner mentioned above (unmodded) and a Holley HP carb with no choke--it was slightly lower than a choked Holley. The Stealth intake itself was not modded in any way.
For the Vic Jr. same motor mounts, modded the above mentioned air cleaner for 7/16" more drop (really easy to do), used the same carb (MUST remove the choke flange on a standard Holley--HP OK as is), and I angle milled the carb mounting flange 3 degrees (from front to rear) to reduce the angle that the carb sat at. About .300" was removed from the front of the pad were the studs are. Translates to about .250 where the actual carb mounting port begins. With the 3 degree angle mill, there is plenty of meat left at the carb pad and the stud angle change is negligible--didn't need to change a thing in order to bolt the carb down.
Carb now sits almost flat again. I still have a true 1/2" of clearance with the stock like hood.
Car runs much, much better with the proper intake and there is virtually no change in lower end torque thanks to the big stroker. Knocked .3 seconds off my 1/4 and gave me 3 more mpg with no other mods. 6400rpm shifts.
And they said it couldn't be done. . . .
