Removed clockspring and saved it. I made a seperate horn button. Although I could have done it but Im lazy. L bought the hub because its sweet looking. You will have a gap between that I filled with a piece of sound deadner
The NRG adapter I bought allows you to keep the clock spring
The one you bought you have to either remove or alter it as per the earlier posts
I believe I simply connected the purple wire off my clockspring to the horn button. but mine is a 90. The alternative method is to connect to the yellow/green wire on the column and run a wire to the horn button. This also was outlined earlier in this thread.
