stock 302 is dead!!!!
  • Thread starter Thread starter dave70
  • Start date Start date Dec 13, 2006
D
dave70
  • Dec 13, 2006
Posting this for a friend who has a 88 gt vert bone stock the motor id dead (bad rod knock) time for a rebuild. What i know about the ford 5.0 is ..not much lol . He wants to go fast. The budget for the motor is about 5,000 .Any suggestions? He still wants it to be reliable enough to drive often but not as a dd. should he ditch the fuel injection and go with a carb or keep it?comp. ratio? i know the 5.o is a stout little motor but what type of comp ratio v.s spray? keep in mind this is a speed density car and not mass air so if he keeps the f.i. that will have to be changed. with his budget how would you build it.I know everyone has a different opinion but that's why i'm asking.with the right suspention setup do you think he can get into the low 11's with spray?thanks for the help guys the only fuel injected car i've ever worked on and raced is my 99 camaro. so i'm new to the 5.0 crowd but i hope i can learn alot helping with his buildup. and sorry if this is posted in the wrong place
blackened88lx
Connecticut
Dec 14, 2006
  • Dec 14, 2006
I'd say low 11s are possible with suspension assuming the car hooks. You will have to be careful because as many people will tell you, the stock 302 block is weak, and is likely to split if you go much over approx. 450rwhp. It's hard to say what exactly you will need for the bottom end without having torn it down yet. If the crank and rods are in good condition, you could get away with buying new FORGED pistons and probably going .030 over to a 306. If not, you might as well do a 331 or 347 stroker. If you don't plan on running boost, you can run a little more compression, but I'd keep it under 11:1 for a street car. The nitrous will like the compression, but watch for detonation on the spray. Personally, I would probably run AFR 185cc heads, but there are many other offerings from Trick Flow, Edelbrock, etc. that would work fine. It sounds like you have a little bit of money to play with, so I would go with a custom cam to match your combo perfectly. As for the carb/EFI question, it depends on your emissions situation. If you have to pass emissions, it would be wise to keep the EFI, and yes, you will need to convert to maf. If you're not worried about emissions, carb it. A 306 with what I mentioned above will probably be 310-330rwhp, so I wouldn't spray it with more than a 100 shot if you want the block to stay together. I hope this helps. You might want to try posting this in 5.0 talk, as there is much more traffic and chance for answers in there.
D
dave70
  • Dec 15, 2006
thanks, he is going to do a forged stroker ass. just not sure what ci. yet
blackened88lx
Connecticut
Dec 15, 2006
  • Dec 15, 2006
Cool. 331 seems to be a more popular stroker choice as there are stories of 347s burning oil. Many people say they do, many people say they don't. I've never run one, so I couldn't tell you, but if I was building one I'd go with a 331 to be safe. With a stroker you will obviously be making more power than the 306 combo, so be careful with the spray. I don't suggest going much higher than 450rwhp.
Here's a pic of a members block after going over 500rwhp.
vristang
4,933
101
124
Seattle
Jan 22, 2007
  • Jan 22, 2007
A MAF conversion will help the EFI stroker motor run better.
A standard A9L computer and PMAS maf setup should work quite well.
Personally, I am a fan of the 351w swap anytime the 302 comes out. The 351w is a stronger block.
Bump/Request to get this thread moved to general tech in hope of more attention.
jason
D
Daggar
3,902
  • Jan 22, 2007
--moved to d to tech--
Rick 91GT
Mustang Master
95
99
PA
Jan 23, 2007
  • Jan 23, 2007
You can work within his budget and go 10's on a 150shot....no problem at all.
Italian-LX
970
Anniston, AL
Jan 23, 2007
  • Jan 23, 2007
I agree with Jason. Especially if you don't have a lot of aftermarket 302 stuff bought yet (intake, headers, lifters, pushrods, etc.).
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
65 Coupe I6 Auto to 302 EFI 5 Speed Swap
  • Scuderia
  • Feb 3, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2025
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
please help! not a typical coyote swap
  • sarver24
  • Nov 15, 2024
  • Other Auto Tech
Other Auto Tech Nov 15, 2024
manicmechanic007
