Stroked 302 and top end kit !!!!
vpap1
109
OK i have a 90 gt a few bolt ons. Intakes , headers, h pipe no cats, CAI, flowmaster cat back, and pullies. Had a vaccum leak (now fixed)and maybe a collector leak in the exhaust. Got dyno'd at 217 at wheel and was hoping for more. So now that winter is here, here comes the new plan. Want to put in a 347 scat stroker kit and the trick flow top end kit as well. I know the TF kits advertises 360 hp but with both kits , the TF top end kit and the stroker kit what will the HP number be..... I am curious.
Wondering what the hp outcome would be?
Also what supporting mods would I need?
What size MAF and TB and Injectores?
Any info would be appreciated.
V
Not sure what a strocker kit is but a 347 stroker kit with the top end kit can easily be made to make 360 hp from what I have seen. But no two motors are the same so there are a lot of variables. You may want to get a custom grind cam depending if you will add a power adder later.
You'll need a 255 lph fuel pump, 70mm TB, 75mm MAF and 30lb injectors at a minimum and probably a good chip and a tune from a reputable tuner to make things work. The engine will only be as good as the supporting upgrades.
