Studs & Head Gaskets
  • Thread starter Thread starter OutlawPony
  • Start date Start date Apr 1, 2006
OutlawPony
12
  • Apr 1, 2006
I have a 306 with a NOVI 2000 and it looks like I have a blown head gasket. I'm going to start tearing it down today. My question is, what's the best route to take as far as replacing the gaskets. I want to try and avoid blowing any more gaskets in the future. 1. Should I use "factory bolts", "performance bolts", or "studs" ? 2. What are the most reliable head gaskets to use on blown 5.0's ? This is the first Stang I've owned with a supercharger, so my knowledgw is very limited when it comes to this.
Thanks in advance for the help.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Apr 1, 2006
  • Apr 1, 2006
how many gaskets have you blown and do you know why it is happening? you wont blow gaskets for no reason, are your heads and block straight and what cylinders are blown.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Apr 1, 2006
  • Apr 1, 2006
To go along with what the guy said above, studs will be best. And unless u know for sure that your heads and block are straight, i would stay away from cometics. I'd go for fel pro 9333-pt1's. Those are known to handle 20psi without problems. But like the guy said above, they just dont blow for no reason. Something causes it....
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Apr 1, 2006
  • Apr 1, 2006
I just went through this. The Techs said to stay away from the 9333PT1 Felpro gaskets as they are nothing more than standard replacement gaskets for early '80s HO cars. The best way (after you check for straightness of the heads and block) is the loc-wire head gaskets IF you have the correct heads. If not, then use Felpro Performance 1011-1 for iron heads and 1011-2 for aluminum heads. then use ARP studs with the moly assembly lubricant. This is what I am about to bolt together.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Apr 1, 2006
  • Apr 1, 2006
Go tell that to all the guys with great success with the 9333's on turbomustangs.com.
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Apr 1, 2006
  • Apr 1, 2006
I run the 9333's
15psi and 544rhwp. My point is with a good tune the gaskets will be fine.
Realmongo
2,466
86
99
Western Mass
Apr 1, 2006
  • Apr 1, 2006
Just passing on what was sent to me from Summit Racing's Tech Assist Department when I told them I only wanted to do it once and do it the right way.
soylentgreen
102
Apr 1, 2006
  • Apr 1, 2006
I think the heads and block need to be machined to accept loc-wire gaskets. But, if there is something else going on (detonation, etc), the loc-wire gaskets will just cause other problems...like broken connecting rods or burned out pistons.
EMW150
2,020
Roaring Spring,PA
Apr 2, 2006
  • Apr 2, 2006
There are many boosted applications out there running nines with the stock replacement Felpros. I've heard more problems running the 1011s than the 9333-pt1 or 8548-pt2. I've been running those gaskets for years. Don't listen to Summit Tech.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Apr 2, 2006
#10
  • Apr 2, 2006
  • #10
I have also heard more bad about 1011s than 9333s. I've also noticed that im pretty sure summit doesnt sale 9333's....i know i cant find them on their site. Maybe that has something to do with his suggestion They are always trying to make a dime
Would you listen to some tech or would u listen to guys that are out here running the parts with the real life experience. Not some hourly guy at a huge warehouse.
Realmongo
2,466
86
99
Western Mass
Apr 2, 2006
#11
  • Apr 2, 2006
  • #11
Yes they sell them. They come in the Fel-Pro Performance package marked part number 1152. I physically had them and was advised to return them for the 1011-1 gaskets which I did.
OutlawPony
12
#12
  • Apr 2, 2006
  • #12
WOW, thanks people for all the replys.
My deal is this:
I bought the car built, so this is the first time it happens. Granted, I've only had the car for a month, so it's happened pretty quick. I'm going to tear it down and send the heads out to check. Right now I want to try and avoid taking the engine apart. My plan is to check the heads, install the studs & gaskets and put her back together. The guy I got the car from said the motor hasn't been apart since it was built 3 years ago with the super charger. From looking at the motor I tend to believe it, it looks like it's been together for a while.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 2, 2006
#13
  • Apr 2, 2006
  • #13
Was the car tuned with that supercharger?
OutlawPony
12
#14
  • Apr 2, 2006
  • #14
Yes, also the motor was built for boost.
But then again, I didn't build it, that's what I was told by the previous owner.
rd
3,316
63
109
Ocean Springs MS
Apr 3, 2006
#15
  • Apr 3, 2006
  • #15
I have run Felpro 9333's and 1011-1's although not with a supercharger, and have never had a problem. The 9333 gaskets are less expensive, more of a stock replacement, but seem to work just fine.
The instructions with my AFR185's say to use 1011-1's on up to 82 engnes and -2's for later ones. Since I have a 68 block, I have used the 1011-1's.
I currently have the stock replacement Victors on there, because that's what Carquest had in stock. They have held up to 100 runs with 30 on spray so far.
I would at least have the heads surfaced. Minimal cut, just enough to make them flat again. My shop did this twice to my Windstar heads without even taking the valves out, and it it worked fine. Just clean them well.
Then reassemble. If it loses another gasket, the block will need surfacing next time.
04sleeper
2,674
14
89
Dallas, TX
Apr 3, 2006
#16
  • Apr 3, 2006
  • #16
If I were to do a blower combo now it would have Cometic head gaskets and ARP studs.
Engine Heads and how to buy
  • Dontknowchit
  • Aug 16, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Head gasket port matching plus head/intake port alignment
  • PonyGTrider
  • Dec 10, 2024
Fox 5.0 Mustang Tech Dec 12, 2024
PonyGTrider
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
