Thanks FoxFan.
that sort of answered my question. I've been planning on a dyno tune and a chip anyways just to solve my idle and driveability problems.
So you are basically saying that If I get the blower just to keep it under 9 psi and to upgrade the injectors? I bought a set of 24#'s that i have never got around to installing cause I need a different mass air meter. think they would be adequate for the supercharger or should I return them and get bigger ones?
I also have a spare set of E7's from my old motor sitting around.
Is it worth it sending them in to thumper (I'm canadian so shipping would probably be alot)
were the thumpers good bang for the buck or should I just save for a set of TFS or eddy's??
you've run both heads.. whats the difference compared to stock??
24s wont be enough by themselves. i say get at least 42s, with the proper tune it wont hurt anything to oversize them a bit.
and i wasnt saying to keep boost under 9 psi, i was just using that as an example as to what can happen if you start upping boost without properly adressing fuel and spark. if i had good control over the fuel and spark i wouldnt have blown a HG and could have upped the boost even more.
before i took the SC off i was running 12-13 psi and it ws running awesome and didnt have a problem.
as for the heads, the thumpers i used worked great, i originally ran a stock motor with bolt ons 3 years ago, i assembled a different engine to put in, i got the thumpers, a tmoss ported stock intake and the b-cam advanced 4 degrees.
i swapped the motor and noticed a pretty good jump in performance. i ended yp swapping the tmoss intake for a typhoon intake, i noticed a slight loss in the LOW end but it picked up a bit in the higher revs. i ran this combo for a year so and the best track times i managed was 13.3 @103, ran pretty good but i THINK i could have got a little more out of it if i kept tinkering. added the supercharger and i got to where i explained in my first post.
as for the TW heads, they make more power across the board. i removed my SC a few months ago and am going to do a turbo setup, but i can remember what the car felt like with thumpers and what i have now, the TW heads make alot more power and the car seems to be alot faster.
the thumpers worked awesome, for a mild setup they work great. but i was looking for more power and i got the better heads.
as for what to get, its all up to what your goals are. if your looking for for a quick street car and arent after max power then ported stock or budget iron heads will be what you can use. if you want more power get the aftermarket heads, there is no denying that they make more power.
IMHO i say if your going to buy new heads get some TFS or edebrocks etc. but if your on a budget you may go the other route. either will be a good bit faster from stock.
