I've never been a big fan of FMU personally... at low boost, you should be able to troubleshoot / survive with an Adj FP regulator and 19Lbs injectors. If it runs better without the FMU, then it's either hooked up backwards or it's just too much fuel pressure at the wrong time. If you're worried about AFRs (you should be), you can fine tune your FMU to spike the fuel pressure a little later and a little less... or just go with bigger injectors/MAF and ditch the FMU.
