supercharger timing
Well you are a bit lean, the AFR does not match the AFR target under load.. If you are running 93 octane and aluminum heads [ I think you are if memory serves] you can easily increase the timing at WOT 100kpa up to 33-34* from 30*
Thanks Steve! And yeah I’m still trying to get WoT fueling dialed in I don’t get much chance to really let it rip on the streets only cruise and light throttle any pointers on best way to go about that? Just do 4th gear pulls?
Ideally, just the required fuel, but it didn't work for me. It developed a low load stumble. Was probably there all the time but wasn't noticeable until the injector change. Steve figured it out.
I upgraded because I, too, was maxing out the duty cycle. Mine's a bit different because I use the MAF for fuel & MAP for spark.
