ok let me be real descriptive with you guys on here then.
i race the car alot, but the "new racing" feel has kinda worn off. i am still going to race, it just may be a little fewer and farther between. with that said, i still plan to do atleast 1 test and tune a month lets say. track here is only open like 5-6 months a year if that.
i drive the car ALOT. for example, this friday im racing it (1 hr each way), saturday im planning to drive 3 hours each way for a car show, sunday 1 hour each way for panhard install.
i put in alot of seat time. i'd like to keep comfort as somewhat of a priority, it rides pretty good now. i hear its even better with a torque arm? that is a big plus to it for me.
so to put this into percentage ratios. i'd say i want 70% drag oriented, 30% towards handling, because i wont ever autocross. i do however like to whip through round abouts, backroads, ect. so it is something i am after improving. my last factor for this is the nearly daily driver duty i put on the car.
so putting that paragraph above together, what FRONT springs do you recommend me?
the car has alot of weight off the front end, i saw someone guesstimate 80 lbs. i think its higher by a good margin. aluminum heads, ac is gone, smog is gone, march pulley/tensioner setup is worth some weight, fiberglass hood, battery is in the trunk, lighter electric fan. then the harness was hidden, so theres a good amount of little brackets/misc that were removed. that is all weight off the springs, so please consider that with your spring recommendation.
