Engine SVE Aluminum Head Swap Question
1989LXFOX
54
Hello all,
I was looking into buying these to put onto my (mostly) stock 302. I ma not planning on racing this car, just ziping around neighborhood. I had a few questions:
Can I use the rocker arms off the stock E7 heads?
Do I really need hardened push rods?
I assume the stock cam will work?
Will they fit BBK headers?
I assume a GT40 (internal EGR) upper and lower intake will fit these?
Still a total novice with cars, sorry if some of the questions are obvious
Thanks in advance!
Stock rockers are pedestal mount, but those heads use stud mount rockers so you will need to buy some.
Should be able to use it with any of the mustang exhaust header offerings.
I believe you need hardened pushrods to prevent wear from the rod guide plates.
You'll also need head bolt reducer bushings
Reactions: 1989LXFOX
Thanks all. I did read a little bit and saw that they do say hardened push rods, I was wondering if they are a must given that I dont race it.
Thanks again
Has nothing to do with racing. It's the guide plates added to the heads that dictate their necessity. Without them, the pushrod will slowly "shave" itself over time as it makes contact with the guide plate and all that metal will find it's way into your oil.
