Greetings from NJ,
I'll be starting the engine/trans swap in a few weeks. The A4LD in my '92 Notch is shot and I intend to swap a T-5 in eventually, but for now I'm just going to swap in the 2.3T and A4LD from the TurboCoupe (taking them out as one piece) just to get rid of the TC and get the Mustang running and drivable. Over the next year or so, I'll pull the motor for a rebuild and do the T-5 swap at that time.
Does anyone have any words of wisdom for me before I get started? I plan on using the LB3 computer from the TC and repinning it for the Mustang (yes, I've read and printed the info from Stinger's site). I'm going to try and keep the premium/regular fuel switch (just need to figure out how). I also need to keep the EGR stuff so I need to figure that out as well. I'll keep the Mustang's 7.5 rear for now, but will be using the 8.8" rear from the TC eventually (it has 3:73 gears like my 7.5 so I won't need to adjust the speedo gear).
Here's a big question: Will the 1988 TurboCoupe engine pass the 1992 Mustang emissions requirements? They are both OBD1, right? so hoepfully it won't be an issue, but I need that EGR to work.
Thanks again,
WES
Thanks again,
WES
