t5 swap pedal question
  • Thread starter Thread starter njoliver
  • Start date Start date May 2, 2010
N
njoliver
259
Columbus OH
May 2, 2010
  • May 2, 2010
alright I got the old pedal assembly out but cannot the new assembly in. do you guys usually pull the steering column totally out? Because I am about to just unhook the steering linkage and pull the steering column out. I was just wondering what you guys usually do.
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,084
224
Massachusetts
May 2, 2010
  • May 2, 2010
Yes, steering column needs to be dropped. Since I had my dash out at the same time, I dropped mine in from the top where the gauges are. Was easier that way
C
C6AE
145
Ma.
May 3, 2010
  • May 3, 2010
I lowered my steering column, but didn't have to pull it out. I knew going in it was going to be a challenge. Took the most part of a day to get it done. Left the AOD in for a few more weeks and when I had some more time, did the rest
KamiKaziDK
555
Mesa, Az
May 3, 2010
  • May 3, 2010
Same, I lowered mine, and it was a bitch to get back in, but if you take a deep breath and have some patience, it will go in no problem. Good luck!
KamiKaziDK
555
Mesa, Az
May 3, 2010
  • May 3, 2010
oh, and you pulled your seat out, right?
Repostyle
538
Portland, OR
May 4, 2010
  • May 4, 2010
As posted, it can be done with the column still attached and just dropped to the floor. But it's just 2 minutes of extra work to completely remove it and get it completely out of the way. I pulled mine out for the pedels. Just get the kids out of the garage and use some profanity and patience.
For my 90 I got the pedals from my 86, I also had to cut off the stud on the dash in the front because it was bigger than the hole in the pedals and made one less thing in the way.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
May 4, 2010
  • May 4, 2010
You're literally one bolt away from taking the column out and it makes a ton more room. Do it.
When I did my swap it took just as much time to swap the pedals as it did to swap the transmission. It is a huge PITA. As previously stated, lots of patience and swearing are required.
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
May 5, 2010
  • May 5, 2010
When i did this it literally took an hour. Droped the column diddnt completely remove it and removed the seat. A little bit of wiggling and the things come right out.Its not the hardest job in the world once you analyze the situation.
stykthyn
5,232
2,652
223
gainesville
May 5, 2010
  • May 5, 2010
once you have done it before its easier the second time. My first go took me roughly a whole afternoon to get the old pedals out and the new ones in. I can do it in about an hour now.
lancec2c30
570
Washington
May 5, 2010
#10
  • May 5, 2010
  • #10
Pull the column, and yes. Lots of swearing is required.
N
njoliver
259
Columbus OH
May 5, 2010
#11
  • May 5, 2010
  • #11
thanks for your guys suggestions I am going to pull the column out. I had plenty of fun trying to get the aod pedal out but did succeed. my cars almost done once I get this finished.
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
A
Resolved Brake light switch
  • Alabama
  • Feb 24, 2025
4K
General karthief
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
