Progress Thread Tannerc91gt’s Build(s) Thread
Got a little done today.
First I managed to go fetch about 63 gallons of e85.
Going to move it into the dark insulated room in my garage but I think it'll be fine sealed tight.
Then I started working on the frame for the fuel cell.
You can see where I plan to put the trans cooler.
Going to remove the mounding tabs and build a "basket" basically for the tank to sit down in. Then I'll use the scrap to build a smaller frame for the trans cooler to bolt to.
Then I'll figure out how to finish out the trunk where it won't look like :poo:.
Finished up the fuel system today.
Had to cut out where the sump is. Unfortunately the 2" drop isn't enough to clear my framing. Worked out alright anyways.
But a bracket for the trans cooler. It'll have a good 3-4" of breathing room between it and the new hatch floor.
Little black spray paint makes it look a lot better than it is.
You can see some real bird:poo: welds if you look for them. Had to break out the flux core mig as I just couldn't get in position to TIG it. Car was too far off the ground to do any good.
Made a new return line and resecured both lines.
Need to make a new floor of some kind so I can remount the battery.
All my wiring stuff showed up so I can gut the car and build a board as soon as I build up the nerve to do so. It might have to wait.
Only a few thing left before its neighborhood road worthy
Soooo,...You're having the same math questions that I had yesterday as well.....
Somethin' ain't addin' up...That's all I know.
2017- 2012= 5...:shrug:
Except I'm pretty sure I really did join in 2007-2008. Not quite the 18 years my profile might suggest but it's been a long time regardless. Noobz might have accidentally gotten something right!
