TFATF NOS question, Don't flame me
Venom_Nitrous
416
Spearfish, SD
Why on the movie Too Fast Too Furious does the manifold pressure go up as shown on his guages when he hits the nitrous. Is the fake, I have a Nitrous system on my car, tho I have never used it and I am just wondering if mine will do this too. Also kinda a separate question, but why the h*** does he have 3 manifold pressure guages?
Because its a movie :D
I know alot of people who run nitrous systems, some who run it on the street. The worst case scenario isn't blowing "the welds in your intake manifold", but rather leaning out in one or more cyls and burning a piston ring, or melting or damaging a piston. Seen it happen more then once with people who didn't adjust their timing.
DUH! everyone knows that too much nitrous will cause the passenger side floor panel to blow. jeez, get it straight.
:jester:
I'm not 100% sure but I dont see anyway that nitrous could build pressure. Most nitrous kits have the nozzle inserted into the intake TUBE not manifold. This is before the throttle body, so it is impossible to build any pressure, because any excess would be blown back out through the air filter. Nitrous is simply air with 33% oxygen instead of the 21% found in the normal atmosphere. Again I do not use nitrous so I am by no means an expert, so maybe someone with experience can back this up.
Andy
Andy
how come intakes blow up with n2o then? :shrug:
sounds like pressure to me? :scratch:
Don't u understand? You need an increase in manifold pressure or else you won't get the flames out the exhaust and make the 3000 people watching you dragrace at 12am go "whoooaaahhh!!!!!". Because thats what it's all about.
1- nitrous is not flamable, it can puddle
2- usually the puddling issue is fuel puddling and only on wet system do you get a boom
3- nitrous is not boost, boost comes from forceing air into the engine, SC or Turbo.
Boost forces more air into the engine to be mixed with more fuel to make more hp.
Nitrous is injected into the air intake as a liquid, the simple way to describe is that nitrous adds more air in a denser form into the intake,, additional fuel is added for the increased air and makes more hp. on a wet kit the N2o system adds the proper amount of fuel by the jets you have installed. on a dry system, the computer adds the additional fuel for the amount of nitrous injected.
nitrous gives the same result as forced induction( more technical than that but you get the picture)
remember that most things in the movie TFTF are not real, especially the wheel stand.............
Install your nitrous kit properly and use it , if you have the correct kit for your car and use it like the manufacturer recommends, you will be fine.
u guys are all kidding right? u do know that its the fuel in a wet system that puddles in the manifold. and there is no manifold pressure at all..only when puddling occurs. and only cylynder pressure is increased with nitrous. just wanna make sure, cuz i dont know if ur fudging with the guy or not (forum isnt really known for straight up tech)
damnit, read above....me=slow typer :rolleyes:
