Ceramic with special cages and different coatings on the cages. Some of the blowers even get more balls in a bearing if that makes sense. They used to use an 11 ball bearing and have recently switched to a 13 ball bearing. This distributes the load much better and keeps these things living at the stupid rpm that we spin them above where they are rated, lolyea pretty much... im assuming the larger stuff run ceramic bearings.
There is actually quite a bit of difference all while keeping quite a bit the same. I'm out of time for at the moment but will put something together later tonight or tomorrow for you as far as a comparison goes from my point of view.Lets ask one more question. What about the vortechs is that much different from the design of the procharger ? Or are they very similar in design ?
There isn't a ton of data available when it come to this technical stuff, all of the race stuff is always so tight lipped, lol. It's pretty cool when you sit and think about the amount of time, money and engineering goes into an air compressoryea i understand the extra balls and all that... just nifty to hear all this stuff
Good to go, cometic is doing something custom for us to try!Racing side of things... tight lipped? Never! Lol did you find a set of gaskets?
X2 please sticky. Excellent info in here.Did this ever get stickied? I had to dig for it.
Stickied, as long as it gets some traffic it will stay StickiedX2 please sticky. Excellent info in here.
You can increase the timing in the tuneup with meth, hence the gain in hp. While beneficial you will need to have a nice system and will want to keep on top of having it full at all times. @RacEoHolic330 can probably elaborate on his meth system as it is one of the nicest I've ever seen installed. Fwiw, I've seen more than a few motors melted down from empty tank or system components that have failed.First I'd like to say I love my V3SI kit from you. It made my Mustang a beast!!! But what kind of gains do you see from some sort of Meth injection. Is it beneficial? Any down sides to Meth injection?
The mondo bypass valve is needed in my opinion at any compressor stage larger than an SI. Functionality wise the Mondo valve flows more air than the plastic valve included with a standard kit. That is the only major difference. Once you start getting into the even larger valves the same premise applies, they just become unable to recirculate the air that you would need for a draw through mass air flow car.I have a couple of questions regarding a for example Anderson bypass kit and mondeo valves @84Ttop. At what hp level will this be useful and quite frankly, how does such a thing work?
