thermerstat??
  • Thread starter Thread starter jimc347
  • Start date Start date Sep 25, 2005
J
jimc347
77
  • Sep 25, 2005
what stat is in the 91 nocthback?? should i put a 180? also i have a air/fuel gauge in the car for the drivers side should i put one for the passanger side??
sunil6784
620
Boston, MA
Sep 25, 2005
  • Sep 25, 2005
stock thermostat would be 192. Most people go with a 180, just don't go down to a 160 as it doesnt let the engine warm up enough to operate optimally.
J
jimc347
77
  • Sep 25, 2005
thanks how about the ail/fuel gauge shoul i put 1 more?
Dean85GT
502
Thorold, Ontario, Canada
Sep 25, 2005
  • Sep 25, 2005
You should install a spelling gauge.
J
jimc347
77
  • Sep 25, 2005
what the hell is a spelling gauge??????????
C
Copperstang87
163
Thunder Bay, Ont
Sep 25, 2005
  • Sep 25, 2005
dont worry hes trying to b a wise ass, just go with a 180 or 192 thermostat.
TrophyHead
1,195
11
49
PA
Sep 25, 2005
  • Sep 25, 2005
The passenger dosent need to know the A/F raito.
Get a 180 stat.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Sep 25, 2005
  • Sep 25, 2005
OMG! ROFLMAO!!!
J
jimc347
77
  • Sep 25, 2005
okay thanks guys.
HISSIN50
34
129
Sep 25, 2005
#10
  • Sep 25, 2005
  • #10
The stat rating depends upon how hot the car actually runs. Some guys with a 180* stat run at 185*F and no more. Other guys in the same conditions can run at 220 with that same stat. So tailor the stat rating to what your car does (this mainly applies to 180 and 195 stats, as 160 really is normally too cold - as mentioned).
For the O2 gauge - you can put a toggle switch on the gauge so you can switch between banks and read what each does.
Good luck.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Sep 25, 2005
#11
  • Sep 25, 2005
  • #11
you put it right near the muffler bearing and your cross drilled brake lines.
D
Daggar
3,902
#12
  • Sep 25, 2005
  • #12
Good luck.
Noooooooo.. can't do that. UNLESS:
You have something else to power the heating element on both sensors. The heaters must be powered when installed in a running motor or they won't last a month.
I'm sure Hiss will have caught that by the time I finish this post.
Edit: Oh wait... we're talking about a gauge on a stock narrow band sensor aren't we? Disregard this post.
D
Daggar
3,902
#13
  • Sep 25, 2005
  • #13
st5150
722
Northern California
Sep 25, 2005
#14
  • Sep 25, 2005
  • #14
This is not true. You can easily wire up both of the O2 sensor's signal wires to a DPST switch and toggle between which sensor you want to read---- but with that said, they'll both more or less read the same and if its one of those red-yellow-green autometer O2 sensor guages, its nothing more than a rice boy light flasher anyways.
D
Daggar
3,902
#15
  • Sep 25, 2005
  • #15
I think you missed the meaning of the post (as I did on Hissin's post). It was meant toward a wideband (whos heater is normally powered by the reader which is normally capable of powering just one heating element at a time). Leaving a wideband sensor unheated in a running exhaust will kill it in no time.
I get what you're saying though. Initially, I missed seeing that were talking about stock sensors (which are already powered).
HISSIN50
34
129
Sep 25, 2005
#16
  • Sep 25, 2005
  • #16
Yep - I was assuming he was using the stock lambdas for the NB gauge.
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
Fox 5.0 Mustang Tech Jul 22, 2026
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
