Those with Bumper Deletes....
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Pulled the front clip and then the bumper and the supports, the bumper itself weights more than the whole front clip with lights and all. I don't plan on putting it back. My question is does the front bumper itself hold the cover at all, I don't want it to flap in the wind. I plan on the same for the rear.
That bumper cover is filled with styrofoam on the 04 stang we have in the yard. There is a 2x2 or bigger square tube made of steel right behind it.
Its plastic in my 88, so what do you think it weighs? I know yours is not a DD, but mine is so I will leave it. Some kind of foam may be a good idea to help keep its shape. Great stuff comes to mind, but that may cost a bit.
If this is in your 90 the bumper should weigh almost nothing -- it's the supports that hold all that weight. Maybe just fabricate new mounts for the plastic bumper (aluminum) -- that way you have some support??
Thanks for the input.
I put the clip back on and as jadedipa said, can't tell unless you push it in. The front cover doesn't touch the actual bumper. I know there isn't anything supporting the front end if it is ever bumped. I've used that bumper a few times when people tried to play games with me, but I shouldn't do that anyways. :bang:
