Throttle body size
  • Thread starter Thread starter stevesLX
  • Start date Start date Mar 14, 2007
stevesLX
373
cincinnati
Mar 14, 2007
  • Mar 14, 2007
I currently have 24# injectors and a 65MM C&L MAF and a 75MM BBK throttle body. Do I need to upgrade my MAF to a 75MM or not. I have been told that my MAF is to small with that TB but then I have been told that the 75MM TB that I have is to big for my mods.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Mar 14, 2007
  • Mar 14, 2007
There is no such thing as a 65mm c&l mass air meter. They only make 73mm and 76mm for foxes. The 75mm tb is fine as long as your manifold inlet is port matched to 75mm,.
stevesLX
373
cincinnati
Mar 14, 2007
  • Mar 14, 2007
O.K. I am just going off of what another person had told me. I do know its a C&L it has that right on it. As far as the intake being ported I have no idea. Whats the easiest way to find that out?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Mar 14, 2007
  • Mar 14, 2007
Take the air tube off and open the TB wide open, look inside and see if the path from the tb to the manifold is the same size with no obstructions. If the manifold inlet isn't port matched, you create a wall for air to hit. What manifold is it?
stevesLX
373
cincinnati
Mar 14, 2007
  • Mar 14, 2007
It is the Edelbrock 5.0 performer
stevesLX
373
cincinnati
Mar 14, 2007
  • Mar 14, 2007
O.K. I just checked by opening the Throttle all the way and it is one clean shot all the way thru and then it narrows down to like a square tube in the intake itself.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Mar 14, 2007
  • Mar 14, 2007
Are you sure its a 75mm tb? The edelbrock opening is only 70mm.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Mar 15, 2007
  • Mar 15, 2007
You do not need a 75mm throttle body, it isn't going to hurt your power, but it sure isn't the most efficient way to get air in your engine. Tip-in and throttle control become a bit more finicky.
Your intake may have already been ported to match.
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
