Throttle body size
stevesLX
373
cincinnati
I currently have 24# injectors and a 65MM C&L MAF and a 75MM BBK throttle body. Do I need to upgrade my MAF to a 75MM or not. I have been told that my MAF is to small with that TB but then I have been told that the 75MM TB that I have is to big for my mods.
There is no such thing as a 65mm c&l mass air meter. They only make 73mm and 76mm for foxes. The 75mm tb is fine as long as your manifold inlet is port matched to 75mm,.
Take the air tube off and open the TB wide open, look inside and see if the path from the tb to the manifold is the same size with no obstructions. If the manifold inlet isn't port matched, you create a wall for air to hit. What manifold is it?
You do not need a 75mm throttle body, it isn't going to hurt your power, but it sure isn't the most efficient way to get air in your engine. Tip-in and throttle control become a bit more finicky.
Your intake may have already been ported to match.
