Timing Chain
  • Thread starter Thread starter BAD67FUN
  • Start date Start date Sep 3, 2004
BAD67FUN
589
Wisconsin
Sep 3, 2004
  • Sep 3, 2004
A very good source of mine and I were discussing things to do to my engine to get a little more kick out of it. First know this. I do NOT want to spend alot on this engine because it's got 130k on the clock. It already has a couple of minor mods... carb, alum. intake and headers. I don't know if I'll buy a crate or rebuild this one... depends on which way the wind is blowing. Anyhow, he mentioned that putting a new timing chain in there would be a very good thing to do. The original one is more than likely stretched or worn out. What are your opinions and what else should I pay attention to or do when doing this swap? Put a nice aluminum water pump in? Stuff like that...
bnickel
5,640
lubbock, texas
Sep 3, 2004
  • Sep 3, 2004
anything you can bolt to the outside of this motor could be used on the new one, like the water pump, you could also go with a different fuel pump since you are right there and though you can't really swap it to the new motor (at least i wouldn't recommend it) since you are going to have the timing cover off anyway you could do a cam swap as well, you can a decent cam/lifter kit from summit for around 100-125 bucks and have a lot more power than that stock cam
LMan
1,246
Mom's basement
Sep 3, 2004
  • Sep 3, 2004
why do you need a new timing chain?
88 Fox GT
1,674
Iowa
Sep 3, 2004
  • Sep 3, 2004
I highly doubt your going to see any power gain from getting a new timing chain, but with 130k on it you might as well just REBUILD the whole engine, timing chain and ALL. Summit Racing actually has a whole rebuild kit with hypereutectic pistons for only $250.
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
  • brandyn200
  • Jun 20, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
