Timing Cover - HELP!!!
  • Thread starter Thread starter The Dan
  • Start date Start date Sep 23, 2004
1 of 2 Next Last
T
The Dan
319
Orange County, CA
Sep 23, 2004
  • Sep 23, 2004
My mechanic just called to tell me that I need a new timing cover as he has found a crack in mine. It is a 65 FB w/ 289 and aluminum water pump. Anyone know wher I can get one quick??? I called John's and Mustang Depot and a local Mustang salvage yard, no luck.
blascrw
191
Opelika, AL
Sep 23, 2004
  • Sep 23, 2004
Ouch....
Mustangs Unlimited lists one on page 58 of their catalog...
65-67 260 & 289 C4AZ6019B $129.95
Give them a try
T
The Dan
319
Orange County, CA
Sep 23, 2004
  • Sep 23, 2004
Mustangs Unlimited said a later model aluminum fox body timing cover would work? Sound right to anyone? I figure they would know.
9
96 DOHC Cobra
542
Cerritos, CA
Sep 23, 2004
  • Sep 23, 2004
It'll work just fine if you have an EFI 5.0 and a rear sump oil pan in your car. The Fox timing cover has no provision for your dipstick or fuel pump.
D
D.Hearne
11,730
south louisiana
Sep 23, 2004
  • Sep 23, 2004
The fox body timing cover is als a reverse rotaion one, ain't gonna work with your water pump. You can't even bolt the pump on it anyway. You need the correct one for that application. Yours is also a passenger side inlet too, you need the timing cover tha also has the timing pointer cast into the cover on the drivers side.
one2gamble
902
Monterey
Sep 23, 2004
  • Sep 23, 2004
call around to the local parts stores. I just picked one up from a place not to far from me.
T
The Dan
319
Orange County, CA
Sep 23, 2004
  • Sep 23, 2004
I didn't think it sounded right. Thanks for the confirmation. I think I have located a repro.
Max Power
1,774
St Paul
Sep 24, 2004
  • Sep 24, 2004
They are pretty easy to find, and I wouldn't recomend a used one. The aluminum tend to pit around the water pump passages over time, and the seal is usually less than perfect.
R
Ronstang
1,294
Houston Texas
Sep 24, 2004
  • Sep 24, 2004
The one he is talking about it NOT easy to find from my experiences. It is the early cover that has a bigger recess because the early aluminum water pump was totally different from the later cast iron one...it has no back plate because the timing cover makes up the back of the housing. A later model timing cover will work as long as you are willing to go with the later model cast iron pump but make sure it has a mechanical fuel pump boss and the correct timing pointerl. I have an early 65 timing cover somewhere and I will look for it if you want me too. I can't remember what condition it is in but I will find out if you really want the correct unit for originality.
T
The Dan
319
Orange County, CA
Sep 24, 2004
#10
  • Sep 24, 2004
  • #10
Ronstang,
Correct you are. This has been a pain in the A$$ to find. The place I oredered from swears the repro they have is for the early style w/ alum. water pump. We'll see.
The covers that are used with the cast iron pumps are a dime a dozen. The aluminum one's are like trying to find Jimmy Hoffa!
R
Ronstang
1,294
Houston Texas
Sep 24, 2004
#11
  • Sep 24, 2004
  • #11
If the repro doesn't pan out let me know and I will dig out the one I have and check it for condition.
Max Power
1,774
St Paul
Sep 24, 2004
#12
  • Sep 24, 2004
  • #12
So the Mustangs Unlimited one listed above won't work?
Dayum, learn something new every day.
CJ Pony Parts lists them used for $129.95. Part number TCC1.
T
The Dan
319
Orange County, CA
Sep 24, 2004
#13
  • Sep 24, 2004
  • #13
It will work...if you have a cast iron water pump.
one2gamble
902
Monterey
Sep 24, 2004
#14
  • Sep 24, 2004
  • #14
can someone post a pic back to back so I can see the difference in timing chain covers. Im curious now as I had no idea they were different. Not the late model one but the two earlier ones
T
The Dan
319
Orange County, CA
Sep 24, 2004
#15
  • Sep 24, 2004
  • #15
Go to E bay, probably the easiest way if you want pics. Just type in each year.
dolfan87
1,242
Lake Havasu, AZ
Sep 24, 2004
#16
  • Sep 24, 2004
  • #16
Summit Racing sells a timing cover...don't know if it is what you need or not.
87
R
Ronstang
1,294
Houston Texas
Sep 24, 2004
#17
  • Sep 24, 2004
  • #17
87
Not...hahahha, the one he needs is fairly uncommon these days. I am surprised he found a vendor with a repro.
Max Power
1,774
St Paul
Sep 24, 2004
#18
  • Sep 24, 2004
  • #18
The one at CJ Pony parts says specifically that it is the early style for aluminum pumps, but it is used. I didn't realize that they list used parts in their catalog, and until today, I didn't realize there were two different covers.
347Fastback
340
Central Coast
Sep 24, 2004
#19
  • Sep 24, 2004
  • #19
I have one I can email pis and I am in cally... I bought it for my 65 fastback but my crate engine has one... Give me your email address...
allcarfan
The Answer Man
2,458
North Atlanta
Sep 24, 2004
#20
  • Sep 24, 2004
  • #20
how bad is the crack? so bad that it cant be drilled and welded?
1 of 2 Next Last
C
1997 3.8l v6 timing cover mismatch *eBay guaranteed fit* haha please HELP
  • chasondragons
  • Apr 3, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 3, 2026
chasondragons
C
Quick question about water pump / timing chain cover
  • D Durden
  • Oct 22, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 6, 2025
GOvert
G
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
LILCBRA
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
