  • 1994 - 1995 Specific Tech
Tips to spring install
  • Thread starter Thread starter deadlast
  • Start date Start date Mar 23, 2006
deadlast
495
Belmont, MA
Mar 23, 2006
  • Mar 23, 2006
i just read through my chiltons manual, and they made it seem alot harder than i thought it would be. Can't i simply jack the car up so the springs have no load on them, then decompress them w/ a spring decompressor to get them out? i would like any other tips please.
91LX_5L
1,943
British Columbia
Mar 23, 2006
  • Mar 23, 2006
yes thats pretty much it, might have to drop the A-arm on the fronts.
deadlast
495
Belmont, MA
Mar 24, 2006
  • Mar 24, 2006
ok well iv been trying all afternoon and im stumped. there simply isnt enough room to have 2 compressors on the spring at once, so i tried to drop the a arm and let the spring fall out. well i have to remove the brake first which is where i got stuck. we tried using a normal ratchet but broke 2 15mm sprockets. so we went out and bought an impact gun to try and get the ****ers off. Nothing! i would love any other tips please.
deadlast
495
Belmont, MA
Mar 24, 2006
  • Mar 24, 2006
hey is it possible to disconnect the strut at the bottom, and just push the a arm as far as it will go down, then just pop the spring out?
donjohn
1,757
Irvine - Southern California
Mar 24, 2006
  • Mar 24, 2006
why do you have to remove the brake? can't you just remove the caliper.
I had my struts off and I think i just dropped (literally the first time) the a arm and the spring still didn't pop out. I had to use a screwdriver or crowbar or something
edit: and i posted while you did.
I believe that's possible.
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
Mar 24, 2006
  • Mar 24, 2006
heres how i did it, and it worked well.....
loosen the 3 bolts that hold the top of the strut (under the hood)...then take out the cotter pin in the big nut on the upper a-arm....take the nut off....take off the nuts on the sway bar and rod ends too....then put a floor jack under the lower a-arm, and lower it down as far as you can go which should take most or all of the load off of the spring in the perch....then try to pry the spring out...if you cant, get some compressors on there, and just compress them a bit, and they should come out pretty easy....then do the same for putting them back in....i didnt have to compress the springs going in because they were about 2" shorter than the stockers, so they went right in....then use the floorjack under the lower a-arm to compress the spring in between the 2 a-arms, and MAKE SURE YOU AIM THE TOP OF THE STRUT BACK INTO THE BOLT HOLES ABOVE! also make sure the spring is sitting in the perches the same way the stockers came out....then tighten tie rod ends, sway bar, and spindle bolts....then tighten the 3 bolts under the hood that hold the top of the strut to the strut tower....hope this helped!
EDIT: one last thing i forgot....get the car maybe 1.5 feet in the air....it will give you the most travel of the lower a-arm and hopefully the spring will pop out easier....and also VERY IMPORTANT, be careful of your front brake lines because you dont wanna tear one..
chaos254
467
NJ
Mar 24, 2006
  • Mar 24, 2006
yeh thats how I did mine... just make sure you put a jack underneath the control arm when your taking the bottom 2 strut bolts off.
Even with the control arm all the way down your going to have to use a pry bar to get it out.
BlackVert
5,589
9
98
Bethesda, MD
Mar 24, 2006
  • Mar 24, 2006
just be careful though because the springs are under alot of pressure and you don't want one popping out on you and right into your face. that woud ruin your day for sure. people often thread a cable through the middle to keep it from going too far it it pops out.
btw, i hope you are happy with the springs, i'm glad they are going to good use.
- chris
spock2001us
143
  • Mar 25, 2006
I took everything off the LCA except the balljoint,and yes, you have to remove the brake caliper which should be simple. You can then push down on the arm and use a crow bar to pull the old spring out. When putting the new one's in, I had to use a spring compressor. If you have the one that uses two pieces that go on the outside of the spring, then you have the wrong one. You need the one that goes inside of the spring, then you have to really play with it to get it to fit right and work.....and I had to use a shim (a short piece of pipe) or else the bolt in the compressor will go beyond the end of the spring....the shim gives you some more room.
deadlast
495
Belmont, MA
Mar 25, 2006
#10
  • Mar 25, 2006
  • #10
we gave up... we couldnt get the damn caliper off. after we broke 2 15mm sockets trying to get the brake off, we bought an impact gun. unfortunatly the compressor tank was too small and couldnt hold a steady psi, so no luck there. im going to give the bolts a nice spray everyday with wd-40 to try and free the bolts up.
Methodical
1,192
11
59
Clinton, MD
Mar 26, 2006
#11
  • Mar 26, 2006
  • #11
Try usnig a Breaker Bar - if not already using one. Get at least a 15" bar and use the impact wrench socket.
JJ95GTID
1,141
Phoenix, AZ
Mar 26, 2006
#12
  • Mar 26, 2006
  • #12
The two 15mm bolts hold the bracket that holds the caliper to the spindle. You could just remove the caliper like you do to replace the brake pads. One bolt on the caliper is a torq bit and the other is an inverted torq bit. they should come off a lot easier than the two 15mm bolts you are trying to remove.
Also, in addition to unbolting the tie rod end, anti sway bar, and struts I also LOOSENED the A-arm bolts. This lets the A-arms drop to the floor. My passanger side stock spring just fell out when I lowered the jack supporting the A-arm after doing this. Just be sure not to retorque the A-arm bolts until you have the full weight of the vehicle support by the A-arm with a jack.
deadlast
495
Belmont, MA
Mar 26, 2006
#13
  • Mar 26, 2006
  • #13
i broke a 2' breaker bar with the impact sockets...
ill try the above method of removing the brake.
Guero
2,148
Mar 26, 2006
#14
  • Mar 26, 2006
  • #14
http://mustangworld.com/ourpics/fcar/steedaspring1.htm
when i did my o1 mustang i looked tru this as i was doing the install
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
Interior and Upholstery Blower motor reinstall
  • Dontknowchit
  • Apr 24, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Engine 1994 5.0 refuses to idle
  • FordFanatic1894
  • Jul 20, 2025
1994 - 1995 Specific Tech Jul 22, 2025
General karthief
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
