tire size calculator??
Mindstatic Pro
107
INDY
My wheels are 19x8.5 up front and 19x9.5 out back. I have 245/35's up front and they look great with the car being lowered. I had 275/30's out back and their overall diameter ended up being just a hare smaller than the fronts. Not super noticeable but an eyesore to me none the less. Im not putting the wheels back on until I get the right size for the rears.
Ive been considering 285/30's, or 285/35's and would like to know the overall diameter of my wheels with these tire sizes before ordering the new ones. I know there is a formula for this but all my googleing hasnt brought up the correct calculators.
I would like the rear overall diameter to be a little bit bigger than the fronts to fill the gap between the tire and fender. Anyone have some suggestions???
That link is dead. I meant to add that I wanted a calculator or formula that included the wheel width. All that I have found only have input for tire size ie. 285/35/19... the width of the wheel will also have an effect on the overall diameter.... 285/35/19 on 8.5 in wheel would be a little different than on a 9.5 inch wheel.
I dont think wheel width is going to affect your diameter enough to matter. Not even 1/10th of inch. I updated the link for you.
http://www.wheelsmaster.com/rt_specs.jsp
Exactly what you want to know is right there!
Here's the specs i put in to compare the two sizes your dealing with:
245/35/19x8.5 (front) overall height = 25.8" (655mm)
275/30/19x9.5 (rear) overall height = 25.6" (649mm)
if you use rear tire size:
285/30/19 the overall height will be 25.8" (655mm) which will match your current overall height in the front.
285/35/19 the overall height will be 26.9" (683mm) which will make the rear a higher overall height than the front.
It's that easy, check it out.
jeffnoel-"I haven't seen a calculator that takes width into the equation."
I dont get it.
I was referring to rim width which is what he asked about in post #3 if you read the whole thread:nono: . And I checked your linked calculator and used the same tire size on 2 different rim widths, it made no difference in overall tire height.:bs: :bang:
rim width will not affect tire height at all.wheather or not the sideall is stretched or not will change the dimension
take a 275/40/17 tire for example
275/ 25.4 = 10.8" in width
10.8X.40(aspect ratio)=4.33" in sidewall
4.33X2(2 sidewalls)=8.66" total sidewall heights
8.66+17(tire size)= 25.66" tire height
