Tires, why is wider better?
MainstreamStang
140
Long Island
Ok, I'm about to get some new tires for my new 18 chrome saleens. Why, besides looking better, should I get wider tires. Right now I have 245/40/17's should I go with 245/40/18's , 265/35/18's or 275/35/18's and why. Thanks
no not always better handling then the proper tire size, if the tire is too big, handling only gets worse. although launching gets better. also with a wider tire on a smaller rim, ride quality suffers, I have experienced this, will never go bigger then standard again
If you have 9" rims I'll go with 275/35 all the way around :nice:
You'll be able to rotate them, the car will look very good , it may track from right to left sometime if the pavement is uneven , this is something you'll get if the car has been lowered and tires are wider .
275/35/18 Eagle F1 on all for corners.
Its already been said....wider tire on the proper width rims=greater contact pathc and more traction.(with correct air pressure)
Lower aspect ratio also reduces sidewall flex and improves cornering ability at the limits.
Thanks for all the replys so quick. The rims are all 18x9 (I did this so I can rotate my tires, so bigger in the back is not an option). Is there a big difference between 265's and 275's, I heard the 275's will rub up front. This car is my daily driver and will be driven in the rain, I will be getting winter tires for my stock 17" wheels, so snow is not an issue. I'm thinking of going with either Toyo or Yokohamma. What do you guys think?
Lots of good responses. If you have the 9's all the way around you will probably like the look of a 265-35-18 on the fronts and 285-35-18 in the rears. You will have no problems with that set up. If your Saleen wheels are authentic then the offset for your rears is different from the fronts therefore no need to buy the same tire all the way around for rotating, Unless you want to unmount and mount again just for a rotation.
If you have the 10 inch rear wheels Saleen or not you will like the look of a 295-35-18 out back. It fills up the wheel well nicely. Some guys get lucky and have no problems going up to 305's and 315's in the rear. It all depends on the set up. You could rub on the quads or somewhere else and some guys don't even notice any "rub" until they get on it in the twisties.
Good luck
ive heard or people squeezing 315 nittos on 9's my personal oppion is go as wide as you can on the rear smaller in the front just looks nicer im runin 245/45/17 front 315/35/17 i know these are not 18's but in terms of width i love this combo i dont really have any rim protection at all on the fronts but i try to avoid hitting crap anyways
I run 265/35/18 in front and 275/35/18 on the back, 18x9's all around. Keep in mind 265/5 is a little shorter than 275/35, and 285/35 is a little taller than 275/35.. but you can run 285/35 out back and have the tire still fit well on the rim.
-wade
wide tires can be tough going in the snow. i assume the greater contact area reduces the average downward force so the tires tend to sit on the snow rather than dig in.
I don't kow how often you stomp on it from a dead stop but, I understand that because of the wider tires are giving you better tracktion it will put more stress on you rear end ~*POP*~. Just wanted to make sure you remember that if you go too wide. :D !Correct me if I am wrong! :D
yes. narrow tires cut throw the snow. however, with 18" Chrome Saleens, I don't think they'll see much snow time :)
gotta love 315 :)
