tires
triumphdick
does anyone have the tire combination of 275/50/17 rears and 255/50/17 fronts? i have a 1996 cobra lowered inch and half with 8 inch rims in the front and 9 inch in the rear and i'm trying to fill the wheel wells.
My 96 has 285/40 on the stock 17s all the way around and fills the wells nicely.
Still need spacers in the rear to fit flush with the lip, atleast 1" and prolly 1.5 would be best :shrug:
Where are you finding a 275/50/17 and a 255/50/17?? That is going to throw off your speedo quite a bit if they make those tires. I don't even think a 255/b]50[/b]/17 would fit and turn up front without rubbing. Sure you didn't mean 275/40 and 255/40?
the tires i'm looking at are falken ziex s/tz-01 from discount tires direct and they are 275/50/17 and 255/50/17. from the info i've gotten so far i think the rears will fit without a problem my biggest concern is if the fronts will fit.
if you go to the direct tire web site and hit search tire by size punch in 275/50/17 and it will come up.
okay i found it by searching on size, but why do you want a truck tire for your car? The sidewall on that tire will be huge.
U.M.
Falken Tire created the Ziex S/TZ specifically for light trucks and SUVs. Not only does the tire feature the stylish tread pattern so you can achieve maximum look for your truck, but they've managed to create the tire with high load carrying capacities - ensuring your safety as well. Going beyond looks and safety, this tire is one you can count on for up to 50,000 miles. And those two wide circumferential grooves move the water out of the way quickly and efficiently, avoiding dangerous hydroplaning.
the wheel and tires i have now look lost in the wheel wells so i'm looking for a tire to fill the void. the tires i have on now are 275/40/17 rears on 9 inch wheels and 245/45/17 front on 8 inch wheels.
