torque these bolts.. you're kidding right?
SeventyMach1 said:
I know this thread is old ...... but in searching, this question came up.
I'm ordering those Breslin's. Will 0.75" work? Or do I have to get the 1" ones?
You need to know how long of a bolt to buy ................... correct :D
If you knew the depth of where the bolt is going you could answer that question :shrug:
Stick a nail or something like it all the way in the bolt hole and mark it next to the header flange and
Badda Bing ... Badda Bang
There you have it :banana:
btw ... a simple lock washer is not as flashy, or a part you can talk a lot about but, its cheap and it works.
Grady
Taken care of in "talk", lol.
Well .... I was ordering the stuff RIGHT THEN. I didn't want to run outside at midnight and pull a header bolt just to see. I figured I'd ask you guys. I didn't get them BTW. I just got some FRPP Grade 8 bolts. The "NEW" engine will sport Breslin's, though. Thanks Grady!
mo_dingo said:
Yeah, that is the same thing with my upper intake, trying to tighten the nuts at the back/front is impossible without grinding down a perfectly good socket. So I just tightened them until they were flush, then about 1/4 turn past that. That should equate to 25 ft.lbs.
Scott
:rlaugh: yea, I had a similar problem, when i was putting on my intake manifold i stripped the very front bolt :nono: I had to go take it all off again and get a helicoil, then re-do it again
