Ok well my TPS is reading 1v at idle. I already checked for open spots and its clear all the way to WOT which reads 4.63v. It should be reading .5-.6v max at idle. I was curious before I replace the TPS if I can just Re-adjust it to .5-.6v at idle which is 600-700rpm. Or are these non adjustable and just need to be replaced. I tried using the search feature but I cant find anything on that. Thank you very much.
