check out moderndriveline.com they can give you a list of everything needed with prices as well. If I can get my email up I'll post back with the list they gave me for converting my 66Gt from auto to the 5spd tremec or t56 6spd.
(edited)
Copied from my e-mail from moderndriveline.com
Here are two quotes, the first it for a T-5z package. this will bolt in without tunnel mods were as the T-56 you will have to cut the top of the tunnel. I posted a few shots as to what that looks like.
65-66 Mustang T-5 325hp
Price
T-5z 2.95 first w/.63od
$ 1,395.00
T-5 Bell housing
$ 215.00
Clutch lever cover
$ 39.00
Block plate
$ 55.00
Flywheel lightened billet steel 28oz
$ 295.00
10.5" Clutch kit, w/bearings
$ 180.00
Clutch lever , cable
$ 43.00
Hardware kit
$ 60.00
Hurst Chrome lever
$ 59.00
Hurst shift ball 5 sp. Pattern
$ 39.00
Hurst shift boot
$ 26.00
Clutch cable kit
$ 259.00
Speedo cable
$ 26.00
Speedo gear
$ 9.50
65-66 mustang T-5 crossmember
$ 149.00
T-5 transmission mount
$ 19.00
Amsoil ATF oil, 3 qts
$ 29.85
Backup light harness
$ 15.00
65-66 Mustang clutch pedal
$ 135.00
Clutch pedal stop
$ 29.00
Pedal pads and trim ring kit
$ 39.00
sub total
$ 3,116.35
Optional equipment
Pedal roller bearing kit
$ 35.00
28 spline slip yoke only
$ 85.00
Steel Driveshaft with yoke
$ 375.00
Aluminum Driveshaft with yoke
$ 495.00
Slik Stik Shifter (clears shifter opening)
$ 295.00
OEM appearance shift lever
$ 139.00
OEM appearance shift ball
$ 39.00
.73 overdrive
$ 159.00
.83 overdrive
$ 189.00
Scatter shield
$ 375.00
Aluminum Flywheel
$ 425.00
Here is the T-56 quote
T-56 package
Price
T-56 six speed, Windsor bellhousing
$ 2,495.00
Clutch lever cover
$ 34.00
Block plate
$ 55.00
Aluminum Flywheel
$ 395.00
Kevlar\Kevlar Clutch kit 10.5"
$ 450.00
Pedal pad/trim rings kit
$ 38.00
Hardware install kit
$ 20.00
$ 35.00
Hurst Chrome lever
$ 59.00
Hurst shift ball 6sp. White, black, Polished
$ 39.00
Hurst shift boot
$ 25.00
Speedometer cable
$ 26.00
Clutch cable kit
$ 259.00
65-73 Mustang T-56 crossmember
$ 190.00
Speedo gear
$ 9.50
Synchromesh oil
$ 29.85
$ 15.00
Clutch pedal
$ 135.00
$ 39.00
sub total
$ 4,348.35
Optional equipment
pedal roller bearing kit
$ 35.00
T-56 Slik Stik shifter
$ 295.00
31 spline slip yoke
$ 89.00
$ 375.00
$ 495.00
67-68 OEM appearance shift lever
$ 139.00
Scatter shield, T-56 Quicktime
$ 425.00
Hydraulic kit with master cylinder
$ 495.00
Aluminum Flywheel
$ 425.00
Regards, Bruce
Modern Driveline Inc.
"Your five/six speed conversion source"
208-453-9800 ext 101
