Trickflow elbow fits which intakes??????
RedGTStang95
9
Heard a lot of different controversy about different elbows fitting different intake manifolds. What's the fittings for these intakes/elbows??????
I'm thinkin about buying this trickflow one from a friend, but I'm not sure if it'll fit different intakes, since I'm lookin at 3-4 manifolds.
Lemme know if anyone has run into this situation.
Basically every elbow fits every intake, however, they have different inner diameters. The Trick Flow has a 75mm opening so you would get the best results by having the upper use the same opening size. Most of the intakes have a 70mm opening and the trick flows have a 75mm opening. So everything but trickflow, you have to port a little bit.
