Trying to pick a clutch?
lefebvrn
24
South Dakota
I am thinking about getting a centerforce clutch. Should I get the Centerforce II or the dual friction? I am dissapointed in my self because I spent the money for a King Cobra and it slips. Is there a better clutch that would be more reliable?
Yeah at your powerlevels, a King Cobra/HD will want to slip after a certain amount of abuse has been put to it.
I would pick the Dual Friction to make sure there is no chance of slip.
I have a Stage II (Centerforce) in my car, daily drove it for quite sometime.
It holds roughly 60% more power than stock. You are around that area...so I would get the DF, although it can be a bit more threatning to the t5.
Just don't powershift it and it will last you many miles:)
I use an centerforce 2 with a fidanza aluminum flywheel and it works realy great, I usualy drive the car hard from time to time, no power shifts just speed shifts and it works fine. Has lasted me longer than expected. The reason i got that clutch is becuase i went through 4 clutches in 5 years, yeah i drive right its just i had junky clutches in it.
