Shadrack said:I was just using a random number really, and yes it is a bit excessive.
40 hp would seem like a more reasonable number to use, probably a little less if it is ported, even less if it is a roots type blower (Kenne Bell, etc.).
Still, Turbo's rule all.![]()
Actually, a roots type supercharger is the least efficient. Centrifugal would be more efficient then the lysholm. The most efficient is obviously the turbo. Don't know any parasitic power numbers off the top of my head though.
The reason the turbos run twins is not only to increase flow at high boost levels, but to improve turbo lag. Two turbos geared to supply sufficient flow at redline will provide boost at a lower rpm than a single (much larger) turbo that provides the same flow at the same redline. So, twin turbos will provide boost in the low rpms and still be ablle to flow in the top end.
Superchargers don't have the low rpm / throttle response issues of a turbo. I seriously doubt there to ever be a design justification for twin SC.
